[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad nsicad at gmail.com
Sat Aug 4 21:56:14 PDT 2012
OK.
Figure it out with -g
python2.7 configure.py -d /Library/Python/2.7/site-packages -b /usr/local/bin -g
GPL v3
Read the license (scroll down)
Accept the license
Yes
make
sudo make install
I think this is important to include -g (as showed above).
Noli
On 8/5/12, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Larry,
> Now, this is the tricky part using my qmake for PyQt and QtSDK.
> I need help in this part.
> Based on the instruction (1)
> /usr/local/bin
> Nolis-MacBook-Pro:PyQt-mac-gpl-4.9.4 nsicad$ python2.7 configure.py -d
> Determining the layout of your Qt installation...
> Error: Qt has been built as static libraries so either the -g or -k
> argument
> should be used.
> Now using the path:
> --qmake=/Users/nsicad/QtSDK/Desktop/Qt/474/gcc/bin/qmake
> --qmake=/Users/nsicad/QtSDK/Desktop/Qt/474/gcc/bin/qmake -d
> argument
> should be used.
> Any ideas how to set this up properly (i.e. install PyQT with qmake)?
> Noli
>> Hi Larry,
>> On 8/5/12, Larry Shaffer <larrys at dakotacarto.com> wrote:
>>> Hi,
>>> Sorry to top post, but... I have not had any significant problems
>>> following INSTALL to build master branch on Mt. Lion today. I have
>>> just updated the Mac notes with some optional info on installing
>>> ccache, and some cmake options for the external libspatialindex [0]. I
>>> did not add any specific info about compiling on Mt. Lion to the
>>> notes.
>> Thanks for updating the documentation on Building QGIS for Mac OS X.
>> More tweaks and a bit more details documentation the better.
>> Now, here is proper logs for building SIP in accordance to the QGIS
>> Mac OS X needs. I am overdriving my homebrew install of SIP.
>> I am using the tarball of SIP (i.e. sip-4.13.3) after I fixed the c++
>> problem.
>> Last login: Sun Aug  5 12:51:29 on ttys010
>> Nolis-MacBook-Pro:sip-4.13.3 nsicad$ python2.7 configure.py -d
>> /Library/Python/2.7/site-packages -b /usr/local/bin -e
>> /usr/local/include -v /usr/local/share/sip
>> This is SIP 4.13.3 for Python 2.7.2 on darwin.
>> The SIP code generator will be installed in /usr/local/bin.
>> The sip module will be installed in /Library/Python/2.7/site-packages.
>> The sip.h header file will be installed in /usr/local/include.
>> The default directory to install .sip files in is /usr/local/share/sip.
>> The platform/compiler configuration is macx-g++.
>> Creating siplib/sip.h...
>> Creating siplib/siplib.c...
>> Creating siplib/siplib.sbf...
>> Creating sipconfig.py...
>> Creating top level Makefile...
>> Creating sip code generator Makefile...
>> Creating sip module Makefile...
>> Nolis-MacBook-Pro:sip-4.13.3 nsicad$ make
>> c++ -headerpad_max_install_names -o sip main.o transform.o gencode.o
>> extracts.o export.o heap.o parser.o lexer.o
>> cc -c -pipe -fPIC -Os -w -DNDEBUG -I.
>> -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7
>> -o siplib.o siplib.c
>> -o apiversions.o apiversions.c
>> -o descriptors.o descriptors.c
>> -o qtlib.o qtlib.c
>> -o threads.o threads.c
>> -o objmap.o objmap.c
>> -o voidptr.o voidptr.c
>> c++ -c -pipe -fPIC -Os -w -DNDEBUG -I.
>> -o bool.o bool.cpp
>> c++ -headerpad_max_install_names -bundle -undefined dynamic_lookup -o
>> sip.so siplib.o apiversions.o descriptors.o qtlib.o threads.o objmap.o
>> voidptr.o bool.o
>> Nolis-MacBook-Pro:sip-4.13.3 nsicad$ sudo make install
>> dyld: DYLD_ environment variables being ignored because main
>> executable (/usr/bin/sudo) is setuid or setgid
>> Password:
>> Sorry, try again.
>> Password:
>> cp -f sip /usr/local/bin/sip
>> cp -f sip.so /Library/Python/2.7/site-packages/sip.so
>> cp -f /Users/nsicad/Downloads/sip-4.13.3/siplib/sip.h
>> /usr/local/include/sip.h
>> cp -f sipconfig.py /Library/Python/2.7/site-packages/sipconfig.py
>> cp -f /Users/nsicad/Downloads/sip-4.13.3/sipdistutils.py
>> /Library/Python/2.7/site-packages/sipdistutils.py
>> As we can see the SIP installed properly for PyQt to use for QGIS.
>> I just like to document this in the list so other Mac OS X (i.e.
>> Mountain Lion) users can use in the future including me :-).
>> Regards,
>> Noli
