[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad
nsicad at gmail.com
Sun Aug 5 00:51:24 PDT 2012
This is better instruction for Installing FastCGI on Mountain Lion.
http://mail.webdna.us/list/talk@webdna.u?cmd=user_listview_msg&domainid=-1&list=talk&msg_idx=9397&rss=true
Larry, probably you can incorporate this in Building QGIS in Mac OS X.
Thanks.
Noli
On 8/5/12, Noli Sicad <nsicad at gmail.com> wrote:
> I think this most important part of using QtSDK for Mac OS X is
> ~/.bash_profile file.
> Create this file and add your bin and lib.
> e.g.
> export PATH=$PATH:/Users/nsicad/QtSDK/Desktop/Qt/474/gcc/bin:$PATH
> export
> LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/Users/nsicad/QtSDK/Desktop/Qt/474/gcc/lib
> And editing the qglobal.h as mentioned by Larry.
> It works in my case. It is compiling PyQt now.
> Noli
>> OK.
>> Figure it out with -g
>> python2.7 configure.py -d /Library/Python/2.7/site-packages -b
>> /usr/local/bin -g
>> GPL v3
>> Read the license (scroll down)
>> Accept the license
>> Yes
>> make
>> sudo make install
>> I think this is important to include -g (as showed above).
>> Noli
>>> Hi Larry,
>>> Now, this is the tricky part using my qmake for PyQt and QtSDK.
>>> I need help in this part.
>>> Based on the instruction (1)
>>> /usr/local/bin
>>> Nolis-MacBook-Pro:PyQt-mac-gpl-4.9.4 nsicad$ python2.7 configure.py -d
>>> /Library/Python/2.7/site-packages -b /usr/local/bin
>>> Determining the layout of your Qt installation...
>>> Error: Qt has been built as static libraries so either the -g or -k
>>> argument
>>> should be used.
>>> Now using the path:
>>> --qmake=/Users/nsicad/QtSDK/Desktop/Qt/474/gcc/bin/qmake
>>> --qmake=/Users/nsicad/QtSDK/Desktop/Qt/474/gcc/bin/qmake -d
>>> argument
>>> should be used.
>>> Any ideas how to set this up properly (i.e. install PyQT with qmake)?
>>> Noli
>>>> Hi Larry,
>>>> On 8/5/12, Larry Shaffer <larrys at dakotacarto.com> wrote:
>>>>> Hi,
>>>>> Sorry to top post, but... I have not had any significant problems
>>>>> following INSTALL to build master branch on Mt. Lion today. I have
>>>>> just updated the Mac notes with some optional info on installing
>>>>> ccache, and some cmake options for the external libspatialindex [0]. I
>>>>> did not add any specific info about compiling on Mt. Lion to the
>>>>> notes.
>>>> Thanks for updating the documentation on Building QGIS for Mac OS X.
>>>> More tweaks and a bit more details documentation the better.
>>>> Now, here is proper logs for building SIP in accordance to the QGIS
>>>> Mac OS X needs. I am overdriving my homebrew install of SIP.
>>>> I am using the tarball of SIP (i.e. sip-4.13.3) after I fixed the c++
>>>> problem.
>>>> Last login: Sun Aug 5 12:51:29 on ttys010
>>>> Nolis-MacBook-Pro:sip-4.13.3 nsicad$ python2.7 configure.py -d
>>>> /Library/Python/2.7/site-packages -b /usr/local/bin -e
>>>> /usr/local/include -v /usr/local/share/sip
>>>> This is SIP 4.13.3 for Python 2.7.2 on darwin.
>>>> The SIP code generator will be installed in /usr/local/bin.
>>>> The sip module will be installed in /Library/Python/2.7/site-packages.
>>>> The sip.h header file will be installed in /usr/local/include.
>>>> The default directory to install .sip files in is /usr/local/share/sip.
>>>> The platform/compiler configuration is macx-g++.
>>>> Creating siplib/sip.h...
>>>> Creating siplib/siplib.c...
>>>> Creating siplib/siplib.sbf...
>>>> Creating sipconfig.py...
>>>> Creating top level Makefile...
>>>> Creating sip code generator Makefile...
>>>> Creating sip module Makefile...
>>>> Nolis-MacBook-Pro:sip-4.13.3 nsicad$ make
>>>> c++ -headerpad_max_install_names -o sip main.o transform.o gencode.o
>>>> extracts.o export.o heap.o parser.o lexer.o
>>>> cc -c -pipe -fPIC -Os -w -DNDEBUG -I.
>>>> -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7
>>>> -o siplib.o siplib.c
>>>> -o apiversions.o apiversions.c
>>>> -o descriptors.o descriptors.c
>>>> -o qtlib.o qtlib.c
>>>> -o threads.o threads.c
>>>> -o objmap.o objmap.c
>>>> -o voidptr.o voidptr.c
>>>> c++ -c -pipe -fPIC -Os -w -DNDEBUG -I.
>>>> -o bool.o bool.cpp
>>>> c++ -headerpad_max_install_names -bundle -undefined dynamic_lookup -o
>>>> sip.so siplib.o apiversions.o descriptors.o qtlib.o threads.o objmap.o
>>>> voidptr.o bool.o
>>>> Nolis-MacBook-Pro:sip-4.13.3 nsicad$ sudo make install
>>>> dyld: DYLD_ environment variables being ignored because main
>>>> executable (/usr/bin/sudo) is setuid or setgid
>>>> Password:
>>>> Sorry, try again.
>>>> Password:
>>>> cp -f sip /usr/local/bin/sip
>>>> cp -f sip.so /Library/Python/2.7/site-packages/sip.so
>>>> cp -f /Users/nsicad/Downloads/sip-4.13.3/siplib/sip.h
>>>> /usr/local/include/sip.h
>>>> cp -f sipconfig.py /Library/Python/2.7/site-packages/sipconfig.py
>>>> cp -f /Users/nsicad/Downloads/sip-4.13.3/sipdistutils.py
>>>> /Library/Python/2.7/site-packages/sipdistutils.py
>>>> As we can see the SIP installed properly for PyQt to use for QGIS.
>>>> I just like to document this in the list so other Mac OS X (i.e.
>>>> Mountain Lion) users can use in the future including me :-).
>>>> Regards,
>>>> Noli
