[Qgis-developer] Map canvas flickers
Kuhn Matthias, Vermessung Matthias.Kuhn at Stadt-Uster.ch
Mon Aug 6 04:31:24 PDT 2012
Which patch did you test?
The first one is known to be broken. Are you sure you didn't test this one?
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] Im Auftrag von Ivan Mincik
Gesendet: Montag, 6. August 2012 12:25
An: Matthias Kuhn; qgis-developer at lists.osgeo.org
Betreff: Re: [Qgis-developer] Map canvas flickers
On 08/06/2012 12:10 PM, Matthias Kuhn wrote:
> Hi Ivan,
> thank you for testing.
> Did you also check if qgis does not crash (as described earlier in this thread, big vector layer, resizing of window)?
> I'm considering releasing a configure option as proposed by Marco.
I am getting segfault at window resizing. GDB log and backtrace here [1].
1 - http://pastebin.com/DVYJEKNC
Ivan Mincik
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
