[Qgis-developer] Map canvas flickers
Kuhn Matthias, Vermessung
Matthias.Kuhn at Stadt-Uster.ch
Mon Aug 6 06:00:25 PDT 2012
I'm on Fedora Core 17, Qt 4.8.
But it seems odd to me, that qt changed these warnings, as there is a good reason for them to appear in the unpatched code and in the case they still appear with the patched code there would be a second call that can result in a paint event somewhere.
Just to be sure: is you qgis loading the correct qgis_core library (i.e. LD_LIBRARY_PATH is set or equivalent other measures taken)
-----Ursprüngliche Nachricht-----
Von: Ivan Mincik [mailto:ivan.mincik at gmail.com]
Gesendet: Montag, 6. August 2012 14:26
An: Kuhn Matthias, Vermessung; qgis-developer at lists.osgeo.org
Betreff: Re: AW: AW: [Qgis-developer] Map canvas flickers
On 08/06/2012 02:11 PM, Kuhn Matthias, Vermessung wrote:
> If that one still crashes, I'm out of ideas.
> The strange thing is, that the warnings you posted on pastebin still appear for you. I'm pretty sure they disappeared on my machine. I'm currently working on a windows system, so I'm unable to verify right now.
Maybe a different QT versions. what kind of Qt, Linux distro do You use ? (Debian Squeeze is with 4.6.3 which is quite old)
Ivan Mincik
