[Qgis-developer] rasterlayertest broken since 2012-08-04
Tim Sutton
lists at linfiniti.com
Tue Aug 7 01:55:39 PDT 2012
Hi
On Tue, Aug 7, 2012 at 9:22 AM, Marco Bernasocchi
<marco at bernawebdesign.ch> wrote:
> On 08/07/2012 09:07 AM, Tim Sutton wrote:
>> Hi
>> On Tue, Aug 7, 2012 at 8:47 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
>>> On Mon, Aug 6, 2012 at 11:41 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>>>> I thought that any failures would be caught by Tim's Jenkins server
>>>>> and I would have received and email.
>>>> Yes I did too - I may have to register the email address of 'users'
>>>> committers which would probably be impractical. If you have and
>>>> android or a iphone, you may want to install the free Jenkins monitor
>>>> tool and point it to my server.
>>>> http://www.jenkins-ci.mobi/
>>> I am not able to get it working, I have filled
>>> Host: jenkins.linfinity.com
>>> and let other options defaults, but Test configuration gives:
>>> Connection test PASSED
>>> Login test PASSED
>>> Retrieve views test FAILED
>>> If I try to connect, it gives "Error while loading data: Internal
>>> server error - 500"
>>> Is it working for you? What params do I have to fill in?
>> Try host jenkins.linfiniti.com (note 'i' at the end)
> works...
> tim that is what you get for drinking too much heidi-water before
> spelling infinity when registering your URL back in 2002 ;)
Ha! Linfiniti is easier to unit test: if name.icount is not 4 assert
'wrong spelling dude!' ....
Tim
> ciao
>> Regards
>> Tim
>>> Radim
> Marco Bernasocchi
> http://opengis.ch
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
