[Qgis-developer] UPDATE: New Plugin - Edit Any Layer
rob.j.nickerson at gmail.com
Wed Aug 8 05:21:57 PDT 2012
This plugin has now been uploaded to http://plugins.qgis.org/ and is
awaiting approval (thanks Paolo).
Changelog:
* New icon
* Added comment to dialogue window
* Changed menu entry to "Edit Any Layer -> Create Editable Layer..."
Alister, thanks for the suggestions but, although the name "Copy as memory
layer" would explain _what_ the plugin does, I will stick with "Edit Any
Layer" as this explains _why_ you would want to run the plugin. I have also
not added an option to copy selected items only (and this is low priority
as this feature is in QGIS core UI).
Regards,
Rob
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120808/05a6b0b0/attachment.html>
