[Qgis-developer] FW: Diagram improvements
Kuhn Matthias, Vermessung
Matthias.Kuhn at Stadt-Uster.ch
Fri Aug 10 00:07:51 PDT 2012
Oops, clicked the wrong button. Here for the list:
> Hi Marco
> Good thoughts. A dimension more really justifies exponential scaling.
> For diagrams scaled by area, we should then use the specified
> diameter for the given attribute value and scale other
> diagrams according to this ratio.
> The other possibility would be to indicate indicate squared units.
> I think the first approach would be better for existing
> projects, as the reference diagram (specified in the layer
> config dialog) would keep its original size.
> Whereas the second approach would lead to immediate resize in
> existing projects but it would be more comprehensible for the
> user that he is scaling by area.
> Matthias Kuhn
> > -----Original Message-----
> > From: qgis-developer-bounces at lists.osgeo.org
> > [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Marco
> > Hugentobler
> > Sent: Friday, August 10, 2012 8:04 AM
> > To: qgis-developer at lists.osgeo.org
> > Subject: Re: [Qgis-developer] Diagram improvements
> > Hi Matthias
> > >In my opinion this is a bug in the current version and should be
> > >changed without option
> > It will be good to have an additional option to scale
> proportional to
> > the area. But I think you should leave the option to scale the
> > diameter.
> > This was done on purpose, because the diagram size you
> specify is the
> > radius, not the area (and this again is similar to the symbology
> > system, where point symbol size is also diameter, not area). Btw, I
> > have read that there might also be cases where you want to scale
> > diagram sizes proportional to the volume (e.g. to display
> content of
> > lakes, etc.).
> > Regards,
> > Marco
> > Am 09.08.2012 14:48, schrieb Kuhn Matthias, Vermessung:
> > > Do you think circular diagrams (i.e. text and pie) need to
> > have an option to scale their radius instead of their area?
> > should be changed without option as it overexagerates
> bigger values.
> > But maybe there is a reason to leave this choice to the user?
> > > Matthias Kuhn
> > Of Matthias
> > >> Kuhn
> > >> Sent: Tuesday, August 07, 2012 5:37 PM
> > >> To: Qgis Developer List
> > >> Subject: [Qgis-developer] Diagram improvements
> > >> Hi,
> > >> I recently started an internship at Uster (a city in
> > Switzerland). My
> > >> job will mostly be to improve QGIS. I'm really looking
> forward to
> > >> this great opportunity.
> > >> My first job is, to improve the diagrams. Any comments
> are highly
> > >> appreciated. (If you think something can be done better
> > differently,
> > >> if you think something is useless, if you are already working on
> > >> something or you know about somebody already working on
> > something, if
> > >> you wanna say thank you...)
> > >> Here a short list of what I've got on my ToDo list.
> > >> - Minimum size for diagrams (As an option, scale any
> > diagram smaller
> > >> than...): Done
> > >> - Text diagram: Center text better vertically (As an
> option): Done
> > >> - Charts are not placed on some polygons (e.g. banana
> > shaped polygons.
> > >> Should this be done with PAL library? Any help appreciated)
> > >> - Ordering: Draw smaller charts on top of bigger one instead of
> > >> hiding
> > >> (randomly?) colliding diagrams.
> > >> - Make diagrams area accurate! By now the radius instead
> > of area is
> > >> scaled.
> > >> - New diagram type: Bar chart
> > >> - New diagram option: Split diagrams. (Pie charts / Bar
> > charts e.g.
> > >> age
> > >> pyramid)
> > >> If you're interested in the current state of work, have a
> > look at my
> > >> git repo [0] on master. Where it says done in the list above you
> > >> should be able to check it out.
> > >> [0] https://github.com/matthias-kuhn/Quantum-GIS.git
> > >> Regards,
> > >> I'm looking forward for comments
> > >> Disclaimer: Sorry if you get this topic the second time.
> I thought
> > >> I'd written something about it yesterday, but couldn't
> > find it in my
> > >> history nor in the archives, so I'll repeat myself and
> > just believe,
> > >> that I missed the send button when I tried to click it.
> > >> _______________________________________________
> > >> Qgis-developer mailing list
> > >> Qgis-developer at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Dr. Marco Hugentobler
> > Sourcepole - Linux & Open Source Solutions Weberstrasse 5,
> > CH-8004 Zürich, Switzerland marco.hugentobler at sourcepole.ch
> > http://www.sourcepole.ch Technical Advisor QGIS Project Steering
> > Committee
