[Qgis-developer] How to color a raster with a color table with values From - To?
SupportLists
supportlists at qlands.com
Mon Aug 13 04:36:43 PDT 2012
I tried that but QgsSingleBandPseudoColorRenderer is a class that does
not seem to exists in 1.8.0
Carlos.
On 08/14/2012 12:25 AM, Etienne Tourigny wrote:
> Hi
> sorry if I have misled you, the code I was quoting is in 1.9 (dev
> version). Have a look at the code in 1.9, it should probably work with
> 1.8 but might require some changes.
> https://github.com/qgis/Quantum-GIS/blob/master/tests/src/core/testqgsrasterlayer.cpp
> //items to imitate old pseudo color renderer
> QList<QgsColorRampShader::ColorRampItem> colorRampItems;
> QgsColorRampShader::ColorRampItem firstItem;
> firstItem.value = 0.0;
> firstItem.color = QColor( "#0000ff" );
> colorRampItems.append( firstItem );
> colorRampShader->setColorRampItemList( colorRampItems );
> Etienne
> On Mon, Aug 13, 2012 at 8:12 AM, SupportLists <supportlists at qlands.com> wrote:
>> Hi,
>> I am using 1.8.0 but tests/src/core/testqgsrasterlayer.cpp is defined as:
>> void TestQgsRasterLayer::pseudoColor()
>> mpRasterLayer->setDrawingStyle( QgsRasterLayer::SingleBandPseudoColor );
>> mpRasterLayer->setColorShadingAlgorithm( QgsRasterLayer::PseudoColorShader
>> mpRasterLayer->setContrastEnhancementAlgorithm(
>> QgsContrastEnhancement::StretchToMinimumMaximum, false );
>> mpRasterLayer->setMinimumValue( mpRasterLayer->grayBandName(), 0.0, false
>> mpRasterLayer->setMaximumValue( mpRasterLayer->grayBandName(), 10.0 );
>> mpMapRenderer->setExtent( mpRasterLayer->extent() );
>> QVERIFY( render( "raster_pseudo" ) );
>> I cannot locate the code using ColorRampItem.
>> Many thanks,
>> Carlos.
>> On 08/08/2012 08:07 PM, Etienne Tourigny wrote:
>>> Hi,
>>> which version of the api are you using? If you are using the
>>> development version (1.9), there is support for more flexible color
>>> ramps with rasters, using QgsVectorColorRampV2. Beware, however, that
>>> the api is going to suffer some changes in the near future. There are
>>> various recent threads on this subject in this mailing list.
>>> Another option (and the only available if using 1.8) is to follow the
>>> approach used in the rasterlayer test in
>>> tests/src/core/testqgsrasterlayer.cpp .
>>> TestQgsRasterLayer::pseudoColor() uses a ColorRampItem vector and
>>> calls colorRampShader->setColorRampItemList(items)
>>> Etienne
>>> On Wed, Aug 8, 2012 at 3:42 AM, SupportLists <supportlists at qlands.com>
>>> wrote:
>>>> Hi,
>>>> I am using QGIS API to develop a custom application. Currently I'm using
>>>> QgsRasterLayer::PalettedColor + QgsRasterLayer::ColorRampShader +
>>>> QgsColorRampShader::ColorRampItem to render a raster using a specific
>>>> color
>>>> map.
>>>> Now, I need to render the raster with a colormap using value From - To
>>>> however, ColorRampItem struct only accepts one value. Is there another
>>>> way
>>>> around? Or, its it possible to create user defined DrawingStyles and
>>>> ColorShadingAlgorithms? If so how?
>>>> Any help is very much appreciated.
>>>> Regards,
>>>> Carlos.
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
