[Qgis-developer] What path for QTWebKit
Andrea Peri
aperi2007 at gmail.com
Wed Aug 15 02:41:47 PDT 2012
Hi Marco,
Thx again for support.
Yes, I install the qt (don't qt4)
and don't have any libqt4-dev
Unfortunately redhat don't give a clear support to QT4.
It allow only this packages:
PyQt4.i686 : Python bindings for Qt4
PyQt4.x86_64 : Python bindings for Qt4
PyQt4-devel.i686 : Files needed to build other bindings based on Qt4
PyQt4-devel.x86_64 : Files needed to build other bindings based on Qt4
avahi-qt4.i686 : Qt4 libraries for avahi
avahi-qt4.x86_64 : Qt4 libraries for avahi
avahi-qt4-devel.i686 : Libraries and header files for avahi Qt4 development
avahi-qt4-devel.x86_64 : Libraries and header files for avahi Qt4
development
pinentry-qt4.x86_64 : Passphrase/PIN entry dialog based on Qt4
poppler-qt4.i686 : Qt4 wrapper for poppler
poppler-qt4.x86_64 : Qt4 wrapper for poppler
poppler-qt4-devel.i686 : Development files for Qt4 wrapper
poppler-qt4-devel.x86_64 : Development files for Qt4 wrapper
I don't know what of this (if any) is the right for qgis.
Andrea.
2012/8/15 Marco Lechner - FOSSGIS e.V. <marco.lechner at fossgis.de>
> Hi Andrea,
> did you install only qtwebkit or also the -dev packages needed for
> compiling (don't know about RedHat, but at Ubuntu/Debian they are
> called libqtwebkit-dev or included in libqt4-dev)
> Marco
> Am Mi 15 Aug 2012 11:18:31 CEST schrieb Andrea Peri:
> > Hi Marco,
> > thx greatly for hint.
> > Unfortunately my problem is opposite to your.
> > I'm having a QTWEBKIT NOT found on configuring phase.
> > So the cmake don't generate the files need for compilation.
> > I guess the cmake search the qwebkit on a different path from where it
> > is installed.
> > I think to have a qtwebkit installed on a 4.6 version.
> > Or perhaps is missing some sub-module of qtwebkit.
> > I don't know.
> > Andrea.
> > <mailto:marco.lechner at fossgis.de>>
> > Hi Andrea,
> > I had a similar problem two days ago, because I tried to compile
> > QGIS "WITH_DESKTOP NO" (just needed QGIS mapserver and Python
> > Bindings). ccmake was succesfull but build failed. may be this
> > info is helpful. jef should have fixed this issue in master (did
> > not try if his fix works)
> > Marco
> > Am 15.08.2012 10:26, schrieb Andrea Peri:
> >> Hi,
> >> I'm try-ing to install the QTWebKit on my RedHat.
> >> But the cmake of qgis still report me it is unavailable.
> >> Perhaps there is a different folder path.
> >> Any hint on where is searched for the QTWebKit and how it is
> >> possible to change se searched path on cmake ?
> >> Thx,
> >> Andrea Peri
> >> qwerty àèìòù
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org <mailto:
> Qgis-developer at lists.osgeo.org>
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Andrea Peri
> > qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120815/bf176105/attachment.html>
