[Qgis-developer] What path for QTWebKit
Matthias Kuhn
matthias.kuhn at gmx.ch
Wed Aug 15 04:07:13 PDT 2012
Hi Andrea,
on Fedora I installed:
* cmake
* flex
* bison
* geos-devel
* gdal-devel
* qt4-devel
* PyQt4-devel
* spatialindex-devel
* libspatialite-devel
* qwt-devel
* qt-webkit-devel
* proj-devel
* gsl-devel
* sqlite-devel
Hope that helps
On Mit, 2012-08-15 at 11:41 +0200, Andrea Peri wrote:
> Hi Marco,
> Thx again for support.
> Yes, I install the qt (don't qt4)
> and don't have any libqt4-dev
> Unfortunately redhat don't give a clear support to QT4.
> It allow only this packages:
> PyQt4.i686 : Python bindings for Qt4
> PyQt4.x86_64 : Python bindings for Qt4
> PyQt4-devel.i686 : Files needed to build other bindings based on Qt4
> PyQt4-devel.x86_64 : Files needed to build other bindings based on Qt4
> avahi-qt4.i686 : Qt4 libraries for avahi
> avahi-qt4.x86_64 : Qt4 libraries for avahi
> avahi-qt4-devel.i686 : Libraries and header files for avahi Qt4
> development
> avahi-qt4-devel.x86_64 : Libraries and header files for avahi Qt4
> development
> pinentry-qt4.x86_64 : Passphrase/PIN entry dialog based on Qt4
> poppler-qt4.i686 : Qt4 wrapper for poppler
> poppler-qt4.x86_64 : Qt4 wrapper for poppler
> poppler-qt4-devel.i686 : Development files for Qt4 wrapper
> poppler-qt4-devel.x86_64 : Development files for Qt4 wrapper
> I don't know what of this (if any) is the right for qgis.
> Andrea.
> 2012/8/15 Marco Lechner - FOSSGIS e.V. <marco.lechner at fossgis.de>
> Hi Andrea,
> did you install only qtwebkit or also the -dev packages needed
> for
> compiling (don't know about RedHat, but at Ubuntu/Debian they
> are
> called libqtwebkit-dev or included in libqt4-dev)
> Marco
> Am Mi 15 Aug 2012 11:18:31 CEST schrieb Andrea Peri:
> > Hi Marco,
> > thx greatly for hint.
> > Unfortunately my problem is opposite to your.
> > I'm having a QTWEBKIT NOT found on configuring phase.
> > So the cmake don't generate the files need for compilation.
> > I guess the cmake search the qwebkit on a different path
> from where it
> > is installed.
> > I think to have a qtwebkit installed on a 4.6 version.
> > Or perhaps is missing some sub-module of qtwebkit.
> > I don't know.
> > Andrea.
> > <mailto:marco.lechner at fossgis.de>>
> > Hi Andrea,
> > I had a similar problem two days ago, because I tried to
> compile
> > QGIS "WITH_DESKTOP NO" (just needed QGIS mapserver and
> Python
> > Bindings). ccmake was succesfull but build failed. may
> be this
> > info is helpful. jef should have fixed this issue in
> master (did
> > not try if his fix works)
> > Marco
> > Am 15.08.2012 10:26, schrieb Andrea Peri:
> >> Hi,
> >> I'm try-ing to install the QTWebKit on my RedHat.
> >> But the cmake of qgis still report me it is
> unavailable.
> >> Perhaps there is a different folder path.
> >> Any hint on where is searched for the QTWebKit and how
> it is
> >> possible to change se searched path on cmake ?
> >> Thx,
> >> Andrea Peri
> >> qwerty àèìòù
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> <mailto:Qgis-developer at lists.osgeo.org>
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Andrea Peri
> > qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
