[Qgis-developer] Python support in project file
Giuseppe Sucameli
sucameli at faunalia.it
Tue Aug 21 03:57:19 PDT 2012
Hi Nathan,
On Tue, Aug 21, 2012 at 10:22 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> - There seems to be a margin around the map canvas now. That wasn't
> there before.
ok, I see it now :)
> - If there are no marcos in the project file I wouldn't show the warning bar.
When the checkbox is unchecked it doesn't show the warning bar,
I'll also check if the textbox is empty.
> - Might be good to have a "more info" hyperlink so that people can
> understand what it really means
A link to the help page, sure it's a good thing.
> - Would be nice if we can to have a Enable Always button with a drop
> down menu with "Always for all projects" and "Always for just this
> project" (don't have it popup a dialog asking if they are sure just
> save it they can always change it after)
Even if I don't like the enable always option as it might cause
security issues, I thought to put just one checkbox in the setting
dialog to make macros always enabled.
I don't imagine how to make the "always enable macros
for just this project" option working.
Projects don't have a identifier like layers and I guess the path is
not a good choice because the project file could be replaced
and the user could easily be wrong.
What do you think?
> - Might need to make the icon have a transparent icon background :)
The icon is the one used for the message logger (displayed
bottom-right when in Debug mode), of course that white
background has to be removed. We also need a icon for
the close button (x) and icons for the other 2 levels of
messages, i.e. critical and information.
Opinions are welcome!
Regards.
> - Nathan
> On Tue, Aug 21, 2012 at 5:54 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>> Very nice Giiseppe. Will test soon.
>> Sent from some fancy phone looking thingo
>> From: Giuseppe Sucameli
>> Sent: 21/08/2012 5:24 PM
>> To: qgis-developer ML
>> Subject: Re: [Qgis-developer] Python support in project file
>> Hi all,
>> I've pushed the code on the branch project_macros on my
>> QGis fork [1].
>> The macros python code is loaded into a dummy module,
>> in this manner it can be unloaded when needed.
>> On Thu, May 31, 2012 at 8:30 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
>>> On Thu, May 31, 2012 at 2:49 AM, Giuseppe Sucameli <sucameli at faunalia.it> wrote:
>>>> I would save it into the project (embedded in the XML) until we will
>>>> have a different way to pack project and related stuff together.
>>> Ok - hopefully XML will not choke python indentation :)
>> It seems conversion to XML doesn't break anything.
>>>> BTW one popup only would be needed, i.e. the project is loaded.
>>>> If the user trust macros then they become active and ready to be
>>>> executed.
>>> See Nathan's post - he better explains what I have meant.
>> I developed a QgsMessageBar class to display information
>> to the user using a non-blocking widget.
>> The bar allows to push more messages as in a queue, then
>> displays them one by one beside to a close button.
>> The button remove the current message or the bar when the
>> message queue is empty.
>> The QgisApp instance creates a object of that class and
>> puts it above the canvas and also on the top of it (so the canvas
>> is not refreshed when the bar is shown or hidden as no resize
>> event occurs).
>> Please, could you test it and report here?
>> Regards.
>> Giuseppe Sucameli - Faunalia
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
