[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
Julien Malik julien.malik at c-s.fr
Wed Aug 29 01:01:03 PDT 2012
Noli,
Le 29/08/2012 06:14, Noli Sicad a écrit :
> Hi William,
> Thanks having a go with this.
> I am using Mountain Lion (10.8.1).
> Would it help if I am going to create this folder,
> /Developer/SDKs and copy the MacOSX10.8.sdk from Xcode?
> The end result would be like this (below) for the directory
>    -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.8.sdk"
> Now, I did this.
> Nolis-MacBook-Pro:OTB nsicad$ mkdir build
> Nolis-MacBook-Pro:OTB nsicad$ cd build
> Nolis-MacBook-Pro:build nsicad$ cmake -D
> CMAKE_INSTALL_PREFIX=/usr/local -D CMAKE_BUILD_TYPE=MinSizeRel -D
> CMAKE_OSX_ARCHITECTURES="x86_64" -D CMAKE_OSX_DEPLOYMENT_TARGET="10.8"
> -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.8.sdk" -D
> OTB_WRAP_QT=OFF -D OTB_WRAP_JAVA=OFF -D OTB_WRAP_PYTHON=OFF -D
> BUILD_APPLICATIONS=ON -D OTB_USE_VISU_GUI=OFF -D
> TIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
> GEOTIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
> JPEG_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
> USE_OPENMP=OFF -D CMAKE_INSTALL_NAME_DIR=/usr/local/lib/otb
> CMake Error: The source directory
> "/Users/nsicad/Documents/Work_1new/OTB/build/CMAKE_INSTALL_NAME_DIR=/usr/local/lib/otb"
> does not exist.
> Specify --help for usage, or press the help button on the CMake GUI.
> Do have any idea why I am getting this error ?
> CMake Error: The source directory "/Users/nsicad/Documents/Work_1new/OTB/build
You are missing the last argument in the cmake command line, specifying
the source directory.
Read again the command line provided by William, and don't miss the ".."
Julien
