[Qgis-developer] Fleet Management Tools
Petros Apotsos
petrosapotsos at gmail.com
Wed Dec 5 08:05:34 PST 2012
Wow,
a most prompt and to-the-point response!! I have absolutely no experience with PostGIS, but it was already in my priorities list, so I will get to it and post back with results and/or comments.
I have to say I disagree with some points of your answers, but I have to do some work first, before posting a formal reply.
Thank you again for your prompt and concise reply,
Petros Apotsos
Rural & Surveying Engineer
Technical Chamber of Greece Registry Number 96798
Τ: 2310 220345
F: 2310 220346
Ermou 18A, Postal Code 54624
Thessaloniki, GREECE
Hello,
> Given a Point Cloud (either a file or a stream) that represents
> positions, speed and direction of a vehicle fleet (TAXIs in my case),
> and a graph (geometric network) that represents roads and
> intersections, I want to be able to do the following:
Your problem will probably be best answered through PostGIS queries, which you can then visualize with QGIS, and/or a custom web-based application.
Let's say you have a table taxi_position like this, where position is a point geometry :
| gid | taxi_id | speed | pos_time | position |
> 1. Track down the route of any single vehicle, as a succession of
> points on the network.
Group by taxi_id, order by pos_time and make a line with the resulting points.
> 2. Calculate the total passes of vehicles through any given point or
> segment of the network.
Join your segment (or node) network with your taxi_position table, allowing a tolerance around the segment/node (st_dwithin will do the trick), then group by taxi if you want to consider each vehicle only once.
> 3. (Not as urgent as the above) Find the nearest TAXI to a random
> point on the network.
With PostGIS > 2.0, use KNN-search to do it fast as light. Otherwise, use st_dwithin with growing values for the search radius.
> All of the above need to be FOSS-based solutions.
check.
> Although I am willing and ready to program plugins or algorithms to do
> the above tasks, I am not really into re-inventing the wheel, so my
> questions are the following:
> A) Are there any libraries or plugins that handle the above tasks?
> Is there any FOSS work already done with them?
That would be a few SQL queries then.
> B) Is QGIS ready (aka efficient enough) to handle those tasks, or
> shall we try other tools/software?
Use QGIS as visualization tool, and PostGIS as a backend, and you're set for hundred of millions of positions without problem (well, do not visualize everything at once).
> Any opinions on my task would be greatly appreciated!
You're welcome
Vincent
> Thanx in advance!
> Petros Apotsos
> Τ: 2310 220345
> F: 2310 220346
> __________ Information from ESET Smart Security, version of virus
> signature database 7766 (20121205) __________
> The message was checked by ESET Smart Security.
> http://www.eset.com
> Qgis-developer mailing list
__________ Information from ESET Smart Security, version of virus signature database 7766 (20121205) __________
http://www.eset.com
__________ Information from ESET Smart Security, version of virus signature database 7768 (20121205) __________
http://www.eset.com
