[Qgis-developer] New FAKE_LIB_GRASS_GIS fails to compile on Mac OS X
John C. Tull jctull at gmail.com
Mon Dec 10 11:57:01 PST 2012
On Dec 10, 2012, at 11:43 AM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> On Mon, Dec 10, 2012 at 12:14 PM, John C. Tull <jctull at gmail.com> wrote:
>> On Dec 8, 2012, at 11:03 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> The  output should be standard shared library. I have probably copy-pasted
>> wrong (provider) block. I have no idea what is the difference on  OS X.
>> Sorry for the problems, i dont have access to source code at this moment,
>> could you try to change
>> CMakeLists.txt to  build simple shared library.
>> Radim
>> On Dec 8, 2012 6:25 PM, "Larry Shaffer" <larrys at dakotacarto.com> wrote:
>>> Hi,
>>> With recent commit:
>>> https://github.com/qgis/Quantum-GIS/commit/4dc84995ee4dec8fe4b927a650b900e7edddaad4
>>> Build of FAKE_LIB_GRASS_GIS fails on Mac OS X with:
>>> Linking CXX shared module ../../../PlugIns/qgis/libgrass_gis.6.4.2.so
>>> clang: error: invalid argument '-compatibility_version 1.9.0' only
>>> allowed with '-dynamiclib'
>>> make[2]: *** [PlugIns/qgis/libgrass_gis.6.4.2.1.9.0.so] Error 1
>>> make[1]: *** [src/providers/grass/CMakeFiles/grass_gis.6.4.2.dir/all]
>>> Error 2
>>> In src/providers/grass/CMakeLists.txt it seems a MODULE, and not
>>> SHARED library is generated (which I think is needed if a framework is
>>> being built), but I do not know enough about this aspect of CMake, or
>>> the build process, to fix it.
>>> Any help would be appreciated.
>>> Regards,
>>> Larry
>> Did anyone come up with a workaround for this? I am still getting the error
>> on my build attempts for trunk:
> Hi John,
> I have a new pull request in for fixing this on Mac, but am not
> entirely sure I did it correctly (or what the new FAKE_LIB_GRASS_GIS
> does or how to test it):
> https://github.com/qgis/Quantum-GIS/pull/349
> https://github.com/qgis/Quantum-GIS/pull/349.patch
> Regards,
> Larry
Hi Larry,
The commit that Radim just made looks like it gets past the build issue. I've not tested the application (or know what to test) to see if the updates are working.
Cheers,
John
