[Qgis-developer] GRASS Direct
Radim Blazek
radim.blazek at gmail.com
Mon Dec 10 13:32:42 PST 2012
On Mon, Dec 10, 2012 at 10:08 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> On Mon, Dec 10, 2012 at 1:53 PM, John C. Tull <jctull at gmail.com> wrote:
>> I wanted to bring my comment I made elsewhere on my Mac testing into this, more appropriate thread:
>> I just tested one of the available modules on a local DEM file, and here is there error message that appeared when I ran it:
>> Cannot start module r.slope.aspect
>> command: /usr/local/Cellar/grass/6.4.2/grass-6.4.2/bin/r.slope.aspect --interface-description
>> ERROR: GISRC - variable not set
>> Note that I am running a version of grass installed locally, not from the application that William makes available.
> Getting the same thing as John here, but with Kyngchaos.com GRASS.
> When using the Kyngchaos.com GRASS, the app starts via an internal
> shell script that configures most of those GRASS env variables [0].
What is the 'app' in this context? GRASS, QGIS or a single GRASS
module? Which variables are set by the script?
As I wrote, there was missing DYLD_LIBRARY_PATH on Mac, please try
also with current master.
Radim
