[Qgis-developer] New Vector API
Paolo Cavallini
cavallini at faunalia.it
Sat Dec 29 09:38:26 PST 2012
Why not releasing a beta before merging?
All the best.
Marco Hugentobler <marco.hugentobler at sourcepole.ch> ha scritto:
>Hi Martin
>Cool, great news! Can't wait to try out the new vector classes. I'm
>away from the computer until 4th of January. Probably other core devs
>are out of contact too, so please make the review period long enough.
>Regards, Marco
>Von Samsung Galaxy Note gesendetMartin Dobias <wonder.sk at gmail.com> hat
>geschrieben:Hi everyone,
>it seems that now it is a good time to ask for a broader review of the
>work I have been doing during recent months: essentially making QGIS
>vector API more flexible and more ready for introduction of threading
>for rendering. That resulted in a greater refactoring of some parts of
>QgsVectorLayer class and QgsVectorDataProvider implementations.
>Everything is in new_vector_api branch in QGIS repository on GitHub
>[1].
>There are few things that are not finished, but should not take too
>much work to sort out:
>- disabled providers - mssql, osm, sqlanywhere, wfs - not yet updated
>to new API
>- disabled mapserver - there are few things to update
>If no serious problems will be found, I would like to merge the branch
>to master and continue working on that on master branch to avoid the
>possibility to drift (again) too much from the quick development that
>happens on master. In short term I plan to do some polishing and
>fixing bugs, then eventually start looking at the threading again.
>For more details about what happened in the branch, see the text below
>(long read!). A great help from early testers would be to compile the
>branch, try to do some "usual" stuff with vectors and see if things
>break apart (crashes? data corruption?).
>Looking forward to your comments!
>Regards
>Martin
>[1] https://github.com/qgis/Quantum-GIS/tree/new_vector_api
>QGIS VECTOR API CHANGES
>1. QgsFeature (changes)
>a) access to attributes by name. Vector data providers and vector
>layer assign pointer to the fields in QgsFeature, so it is possible to
>set/get attributes by their name. This is not as efficient as with
>direct access by index, but often this convenience is useful for
>users.
>b) attributes are stored in a QVector container rather than a QMap.
>The major advantage is simplification of logic related to handling of
>attributes: it's not possible to have "holes" in the array of
>fields/attributes. Currently it is possible that for example layer
>with three fields returns indexes 0,1,3 - but it is not so common nor
>obvious, so it's a common source of errors. After refactoring there
>must not be any holes, so a layer with three fields always returns
>indexes 0,1,2. When iterating over layer's features, QgsFeature always
>contains a vector of all layer's attributes. In case the client has
>not requested attributes to be fetched, the attributes contain invalid
>values.
>2. QgsFields (new class)
>Just like attributes within a feature are stored in a vector instead
>of map, also layer's fields are now stored in a vector. QgsFields is a
>new class that mimics QVector API and adds two more pieces of
>functionality:
>a) fast lookup of field index from name. When QgsFields is populated
>with fields, it creates a map of fields that facilitates fast lookups
>b) detection of field origin. When working with a vector layer, it is
>sometimes useful to find out origin of the field - whether it comes
>from provider, from a join or whether it is a newly added field (not
>committed). In the future we could add also expression-based fields,
>creating a field calculator that calculates the values on the fly.
>3. QgsFeatureRequest (new class)
>Class that encapsulates requests for features to a vector layer or
>vector data provider. Right now in master branch, the request is
>defined by arguments to select() method. That's not very flexible nor
>simple to use. Feature request class allows easier extensibility in
>future (support generic expression filter, native provider's SQL
>filter...).
>Without any customization, the request will ask for all features with
>geometries and attributes - somehow better default that the current
>one that does not fetch attributes if their list is not explicitly
>given.
>(I'm not yet completely happy with the API of this class, so it may be
>changed to some degree. Suggestions are welcome.)
>Examples:
>- fetch all features:
> QgsFeatureRequest()
>- fetch all features, only one attribute
> QgsFeatureRequest().setSubsetOfAttributes(QStringList("myfield"),
>provider->fields())
>- fetch all features, without geometries
> QgsFeatureRequest().setFlags(QgsFeatureRequest::NoGeometry)
>- fetch only features from particular extent
> QgsFeatureRequest().setFilterRect(QgsRectangle(0,0,1,1))
>- fetch only one feature
> QgsFeatureRequest().setFilterFid(45)
>4. QgsFeatureIterator (new class)
>The iterator class allows iteration over features of a vector layer or
>a provider. It contains the usual nextFeature() method that fills
>given QgsFeature class with data.
>Internally, this class is a wrapper around QgsAbstractFeatureIterator
>interface that is implemented by each vector data provider and by
>vector layer. In theory we could use directly
>QgsAbstractFeatureIterator pointers, but this wrapper allows us to use
>it as a local variable, so it gets destroyed automatically when it
>gets out of scope, not requiring an explicit "delete" call that would
>be necessary with a pointer (easy to forget, right?)
>5. Access to features
>Vector layer and providers implement one important method call:
>getFeatures(). It takes single argument (QgsFeatureRequest) and
>returns QgsFeatureIterator. This replaces select(), nextFeature(),
>rewind() and featureAtId() methods.
>This approach allows users to create multiple iterators over a vector
>layer (or a vector data provider). But currently that's not supported
>because this needs support in the providers. At some point, we could
>add support for simultaneous iterators - something that old API does
>not allow at all.
>When QgsFeatureIterator instance of a particular layer is closed (by
>calling close() or destructed), then a new getFeatures() call may be
>issued.
>6. QgsVectorLayerEditBuffer (new class)
>All editing functionality of vector layer has been moved out of
>QgsVectorLayer into a new class that stores everything related to
>editing: added features, removed features, changed geometries, changed
>attribute values, added attributes, removed attributes. This class is
>accessible from QgsVectorLayer, but it exists only when the layer is
>in editing mode - it is deleted once features are rolled back or
>committed.
>The undo/redo support has been completely rewritten and greatly
>simplified: instead of one undo command that gathers changes within
>the edit buffer, there is now one undo command implementation for each
>action. The undo commands can be grouped together with QUndoStack
>macros. The new implementation ensures that the undo stack does not
>get out of sync, because all editing changes are stored onto undo
>stack (unlike current implementation in master branch where
>begin/end-UndoCommand() methods must be called before/after edit
>operations to ensure correct behavior of undo).
>7. QgsVectorLayerEditUtils (new class)
>Advanced editing operations that operate on vector layers (e.g. add
>part) that can be composed from one or more simple edit operations
>have been moved out of QgsVectorLayer and its edit buffer, so that the
>vector layer API is not polluted by methods that do not need access to
>its private members.
>8. QgsVectorLayerCache (new class)
>To speed up geometry editing, QGIS keeps a cache of geometries
>currently shown in map canvas. This cache has been decoupled from
>editing operations and moved to a separate class to keep things tidy.
>In the future we should be able to add more general caching scheme to
>allow faster rendering of vectors. Also, this might be a good place to
>store index of feature ID -> row number that is calculated every time
>when attribute table is opened.
>9. Python
>Python API has been updated to support functionality from the points
>above, that is access by attribute name and support for python
>iterators, e.g.:
>for feature in layer.getFeatures(request):
> print feature["road_id"]
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-developer
http://faunalia.it/pc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121229/86254d85/attachment.html>
