[Qgis-developer] Composer redesign
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Fri Feb 3 10:14:54 EST 2012
Hi Nathan
The changes to the composer UI look great.
+1 for integrating into master branch.
Regards,
Marco
On 02.02.2012 14:06, Nathan Woodrow wrote:
> Hi all,
> Tonight I did some tweaking to the composer window. A few things had
> been bugging me a for a while now and I decided I would have a go at
> fixing some of them, or at least try to anyway.
> The general changes are:
> * Redesign the composition (general) tab to remove the need
> to vertical scroll, in most cases. (Not a perfect redesign but it
> works IMO much better then the old layout)
> * Remove wasted space around paper area and widget (see picture[1]
> vs your install to see the difference)
> * Convert the split widget + tab widget to QDockWidgets. 1) The
> splitter didn't remember its last position or state 2) Could only
> view one tab at a time 3) The main QGIS window uses dock widgets
> to allow flexibility in screen layout, composer should too. 4)
> Can't hide tabs if you don't need to see them all the time e.g.
> command history . Using dock widgets solves all of these issues.
> The current working branch can be found at
> https://github.com/NathanW2/Quantum-GIS/tree/composer-redesign
> I have also attached [1] an annotated screen shot if you don't want
> to compile the branch.
> If I could get some general feeback and testing that would be good,
> keep in mind it's not a final copy and I will tweak things as I go.
> I'm currently adding it so the dock windows remember the state, just
> like the main QGIS dock widgets, but that isn't in the branch yet.
> [1] http://imageshack.us/photo/my-images/525/composer1026.png/
> Thanks,
> Nathan
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120203/b5cffe6a/attachment-0001.html
