[Qgis-developer] QGIS-server in master
Yves Jacolin yjacolin at free.fr
Tue Feb 7 10:49:37 EST 2012
Thanks to Marco I successfully tested my qgis-server.
The issue below (getCapabilities) is not anymore in master. I didn't test it
on QGIS 1.7 branch as it failed to build at this moment (libqwt issue).
Thanks,
Y.
Le lundi 06 février 2012 10:31:38, Yves Jacolin a écrit :
> Thanks Marco I will send you in private some test file tonight. I really
> checked several time the map parameter :)
> I have an another issue. It seems that the GetCapabilities is not correct:
> * MapServer's GetCapabilities:
> <WMS_Capabilities version="1.3.0" [..]>
> <Service>
>   <Name>WMS</Name>
>   <Title>OpenOcean_WMS_T</Title>
>   <Abstract>OpenOcean_WMS_T</Abstract>
>   <OnlineResource xlink:href="localhost?"/>
>   <ContactInformation></ContactInformation>
>   <MaxWidth>4000</MaxWidth>
>   <MaxHeight>4000</MaxHeight>
> </Service>
> <Capability>
> * QGIS' Capabilities:
> <Name>WMS</Name>
> <Title>Facilities</Title>
> <Abstract/>
> <Capability>
> As you can see <Service> tag is not used in QGIS server (1.7.0). I will
> test it tonigh with my datraset on QGIS master.
> thanks,
> Y.
> Le lundi 06 février 2012 08:52:35, Marco Hugentobler a écrit :
> > Hi Yves
> > QGIS server from trunk works for me (at least with some test projects).
> > Are you sure the map-Parameter of the request is correct?
> > If yes, could you paste the request url and maybe send a small set of
> > testdata and demoproject?
> > Regards,
> > Marco
> > On 05.02.2012 17:04, Yves Jacolin (free) wrote:
> > > Hello,
> > > I have just built QGIS from master (up to date on the 5/02 15h56) to
> > > test qgis server.
> > > I already have this message:
> > >> Configuration file problem : perhaps you left off the .qgs extension?
> > > I checked that my filepath to my qgis project is correct, "chmod" it to
> > > a+rwx but I have no more idea.
> > > The good news  is that my flipped raster which I talked in another
> > > thread this week is now correct.
> > > Thanks,
> > > Y.
Yves Jacolin
http://yjacolin.gloobe.org
