[Qgis-developer] Windows Installation broken - and cannot
uninstall
Jürgen E. Fischer
jef at norbit.de
Wed Feb 8 04:26:40 EST 2012
Hi Ole,
On Wed, 08. Feb 2012 at 15:39:22 +0700, Ole Nielsen wrote:
> This application has failed to start because ippqj-5.3.dll was not found.
> Re-installing the application may fix this problem.
Is that because you installed the libjpeg-ipp package? That doesn't ship
with all dependencies - see [1]
If you just select qgis(-full) or qgis-dev in the installer you should get all
needed dependencies.
Jürgen
[1] http://trac.osgeo.org/osgeo4w/wiki/pkg-libjpeg-ipp
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
