[Qgis-developer] Windows Installation broken - and cannot uninstall
Jürgen E. Fischer jef at norbit.de
Wed Feb 8 10:24:46 EST 2012
Hi Alister,
On Wed, 08. Feb 2012 at 14:26:47 +0000, Alister  Hood wrote:
> > Use the standalone installer, is less risky to have something get wrong.
> 2. Is it really so necessary to dissuade people from using the OSGeo4W "Setup"?
> - It is much quicker and easier.  E.g. when a new version of QGIS is released
>   you only need to click through setup again to update.  You don't need to go
>   to the QGIS website, download a new installer (which will waste time and
>   bandwidth because it is bigger - especially since it includes GRASS, which
>   many people would never use), run the installer, and separately run the
>   uninstaller for the old version.
The usual argument is that people are used to (<bias>huge and bloated</bias>)
standalone installers.  And those are easier for places with slow connectivity
(or off-net).  I'm not sure about that either - especially when updates are
considered.
I don't recommend the standalone installer either - I just make it ;)
But that's done from the osgeo4w packages anyway.
> - I'm not convinced the OSGeo4W installer is very risky.  Are people having
>   problems with it without doing an "advanced install" and choosing weird
>   things
Me neither - and yes, I think that installing stuff, that the (documented) need
of third party dependencies was the trouble maker again.
> - always install "setup" - make it a dependency of every other package.
> - change the label of "setup" in the start menu to something which makes it
>   really obvious that this is how you add/remove/upgrade/rollback packages.
Sounds good and easy.
> - Explain that if you want to remove _everything_ you can just delete the
>   main OSGeo4W folder.
> I guess it would be _possible_ to make the osgeo4w installer automatically
> install "setup", and put something in the Windows "add remove programs" to
> launch it, but it would require more work...
That's probably not that difficult - just needs some googling - and some time
Jürgen
-- Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
