[Qgis-developer] (basic) python help
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Feb 9 04:50:27 EST 2012
Hi Martin, Hi Nathan,
Thank you both for your replies.
The solution was effectively using exec. The difference is not very
straightforward but I think I got it!
Btw, I am using this to save list in a layer custom property, and the
way I found is playing with repr and eval exec.
Thanks again! You save me a lot of time, I was not looking in the right
direction!
Denis
On 02/09/2012 10:41 AM, Martin Dobias wrote:
> On Thu, Feb 9, 2012 at 10:33 AM, Denis Rouzaud<denis.rouzaud at gmail.com> wrote:
>> Hi all,
>> I am dealing with the same problem for a while now, can someone tells me why
>> these commands give a syntaxerror:
>> eval("myvar ='3'")
> There is a difference between evaluation (eval) and execution (exec)
> of some code. When evaluating you only want a result of an expression.
> When executing you actually run one or more statements in the current
> context.
>>>> eval("1+2")
> 3
>>>> exec "x=1"
>>>> x
> 1
> Also note that exec is a statement (no parentheses) while eval is a
> builtin function.
> Martin
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120209/ac45867b/attachment.html
