[Qgis-developer] Re: Windows Installation broken - and cannot
uninstall
Alister Hood
Alister.Hood at synergine.com
Thu Feb 9 19:47:28 EST 2012
> Date: Wed, 8 Feb 2012 21:35:20 +0100
> From: Andrea Peri <aperi2007 at gmail.com>
> Subject: [Qgis-developer] Re: Windows Installation broken - and cannot
> uninstall
> To: qgis-developer ML <qgis-developer at lists.osgeo.org>
> Message-ID:
> <CABqTJk-P3kzHsXs6p-5XVd2HsOq-D=vWfJ=fV9vFVNY-HAZmWw at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> >* 2. Is it really so necessary to dissuade people from using the
> >OSGeo4W*>* "Setup"?*>* - It is much quicker and easier. E.g. when a
> >new version of QGIS is*>* released you only need to click through setup
> >again to update. You don't*>* need to go to the QGIS website, download
> >a new installer (which will waste*>* time and bandwidth because it is
> >bigger - especially since it includes*>* GRASS, which many people would
> >never use), run the installer, and*>* separately run the uninstaller
> >for the old version.*>* - The OSGeo4W setup also provides easy access
> >to other software you might*>* want to use with QGIS (and nightlies in
> >case you need them :) )*
> A problem with the osgeo-setup is that the newbye user could run an "install all" and so install on its machine the web softwares.
> When this was happened , the machine begin to run slow. And the remove of the web software was a bit of panic, expecially from the services.
But there is no option to "install all". Am I missing something?
Alister
