[Qgis-developer] Android qgis alpha5
Andreas Neumann a.neumann at carto.net
Fri Feb 17 08:11:51 EST 2012
on my Android phone the CRS database is missing/empty. I cannot select a
CRS.
Can someone confirm if the CRS db is present on Master 5?
Thanks,
Andreas
On 02/17/2012 01:16 PM, Marco Bernasocchi wrote:
> Hi andreas
> Marco Bernasocchi (mobile)
> www.opengis.ch
> On Feb 17, 2012 12:50 PM, "Andreas Neumann" <a.neumann at carto.net> wrote:
>> Hi Marco,
>> Thanks for the note - sounds encouraging.
>> I have a strange issue with the install. The Master 5 downloads file and
>> then installs for a while. At the end I get a message "Anwendung nicht
>> installiert" (application not installed), but with a green checkmark. To
>> me the green checkmark looks ok, but why is saying "Anwendung nicht
>> installiert"?
> Mmm the installation is taken care of by the android installer.
> Try uninstalling qgis, I started signing the packages from this release and
> they might conflict.
>> How can I check if the application is equivalent with master5?
> If it has right click. Its mastet 5
>> In the about dialogue I don't get a version number. QGIS code revision
>> reports as "exported".
>> Regarding right-click: where is right click supported? Everywhere where
>> it should work (e.g. layer manager) or just for digitizing?
> Normally everywhere, I tested digitizing and legend.
> Ciao
> Ps maybe u can fwd the note to qgis.ch
>> Thanks,
>> Andreas
>> On 02/17/2012 11:25 AM, Marco Bernasocchi wrote:
>>> Hi all yesterday I pushed a new alpha version of qgis for android on
>>> android.qgis.org
>>> This release includes all the goodies that I got to implement lately
>>> including:
>>> - right click support through longClick
>>> - shape file support
>>> - gps
>>> - compass
>>> - android 4 support
>>> - partial hardware optimization for armV7a (most newish devices have it)
>>> - no debug symbols
>>> I m very happy with this release because it adresses and fixes all high
>>> priority bugs.
>>> Adding support for a armv7a optimized whit no debug symbols build
> increased
>>> greatly the speed of the app. The package you need to install is the
> same
>>> and includes both armv5 and armv7a code. Android will take care of using
>>> the correct version. Gdal and geos are not available yet in v7a code so
> the
>>> v5 versions will be loaded.
>>> I couldn't test much the v7 code so I hope you can help me testing it.
>>> As well, on www.opengis.ch I published many videos and screenshots  of
> qgis.
>>> As usual, please remember if you can (or if you know anybody that could)
>>> that sponsoring would help a lot implementing some more great features.
>>> Ciao
>>> www.opengis.ch
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
