[Qgis-developer] Solved: qgis python plugin: change to select tool
qgis-g
scharforama at googlemail.com
Fri Feb 17 12:16:52 EST 2012
Solved!
dir(qgis.utils.iface.actionSelectRectangle()) in qgis python console
returns:
['AboutQtRole', 'AboutRole', 'ActionEvent', 'ApplicationSpecificRole',
'HighPriority', 'Hover', 'LowPriority', 'MenuRole', 'NegativeSoftKey',
'NoRole', 'NoSoftKey', 'NormalPriority', 'PositiveSoftKey',
'PreferencesRole', 'Priority', 'QuitRole', 'SelectSoftKey', 'SoftKeyRole',
'TextHeuristicRole', 'Trigger', '__class__', '__delattr__', '__dict__',
'__doc__', '__getattr__', '__getattribute__', '__hash__', '__init__',
'__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__',
'__setattr__', '__str__', '__weakref__', 'actionGroup', 'activate',
'associatedGraphicsWidgets', 'associatedWidgets', 'autoRepeat',
'blockSignals', 'changed', 'childEvent', 'children', 'connect',
'connectNotify', 'customEvent', 'data', 'deleteLater', 'destroyed',
'disconnect', 'disconnectNotify', 'dumpObjectInfo', 'dumpObjectTree',
'dynamicPropertyNames', 'emit', 'event', 'eventFilter', 'findChild',
'findChildren', 'font', 'hover', 'hovered', 'icon', 'iconText', 'inherits',
'installEventFilter', 'isCheckable', 'isChecked', 'isEnabled',
'isIconVisibleInMenu', 'isSeparator', 'isVisible', 'isWidgetType',
'killTimer', 'menu', 'menuRole', 'metaObject', 'moveToThread', 'objectName',
'parent', 'parentWidget', 'priority', 'property', 'pyqtConfigure',
'receivers', 'removeEventFilter', 'sender', 'setActionGroup',
'setAutoRepeat', 'setCheckable', 'setChecked', 'setData', 'setDisabled',
'setEnabled', 'setFont', 'setIcon', 'setIconText', 'setIconVisibleInMenu',
'setMenu', 'setMenuRole', 'setObjectName', 'setParent', 'setPriority',
'setProperty', 'setSeparator', 'setShortcut', 'setShortcutContext',
'setShortcuts', 'setSoftKeyRole', 'setStatusTip', 'setText', 'setToolTip',
'setVisible', 'setWhatsThis', 'shortcut', 'shortcutContext', 'shortcuts',
'showStatusText', 'signalsBlocked', 'softKeyRole', 'startTimer',
'staticMetaObject', 'statusTip', 'text', 'thread', 'timerEvent', 'toggle',
'toggled', 'toolTip', 'tr', 'trUtf8', 'trigger', 'triggered', 'whatsThis']
So I tried:
qgis.utils.iface.actionSelectRectangle().trigger()
and it worked!
In plugin I use:
self.iface.actionSelectRectangle().trigger()
View this message in context: http://osgeo-org.1560.n6.nabble.com/qgis-python-plugin-change-to-select-tool-tp4476490p4480922.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
