[Qgis-developer] Re: No GRASS plug-in
Zirneklitis eko at lanet.lv
Wed Feb 22 09:38:02 EST 2012
It looks like there is something wrong with the GRASS plug-ins for 1.9.90 :
2012-02-22T14:15:53	Failed to load
C:/OSGeo4W/apps/qgis-dev/plugins/grassplugin.dll (Reason: Cannot load
library C:/OSGeo4W/apps/qgis-dev/plugins/grassplugin.dll: The specified
module could not be found.)	0
C:/OSGeo4W/apps/qgis-dev/plugins/grassprovider.dll (Reason: Cannot load
library C:/OSGeo4W/apps/qgis-dev/plugins/grassprovider.dll: The
specified module could not be found.)	0
C:/OSGeo4W/apps/qgis-dev/plugins/grassrasterprovider.dll (Reason: Cannot
load library C:/OSGeo4W/apps/qgis-dev/plugins/grassrasterprovider.dll:
The specified module could not be found.)	0
At the same time:
  Directory of C:\OSGeo4W\apps\qgis-dev\plugins
2012.02.15.  10:07         1˙730˙560 grassplugin.dll
2012.02.11.  18:14           245˙760 grassprovider.dll
2012.02.11.  18:16           116˙736 grassrasterprovider.dll
Best regards,
Karlis
Salvatore Larosa wrote:
> Hi,
> look at the messages log on the bottom left (triangle with exclamation
> point) and check if plugin is loaded correctly!
