[Qgis-developer] OS X 1.7.4... bomb
William Kyngesburye woklist at kyngchaos.com
Sat Feb 25 15:49:05 EST 2012
Haven't solved it yet i QGIS compiles and runs, you just can't open any help.  I'm setting up a spare 10.6 Mac to compile Qt from source so it shouldn't reference anything from 10.7.  Odd that you'd get a 10.7 reference compiling on 10.5, time warp?
On Feb 25, 2012, at 2:25 PM, Marco Hugentobler wrote:
> Hi William
> >Nokia screwed up compiling their "official" binaries. Everything BUT QtWebKit works on OS X 10.6 (Snow Leopard).
> >QtWebKit appears to use a OS X 10.7-only system function. This breaks QGIS help and some plugins on OS X 10.6.
> >It's possible it's not really Nokia's fault. I'll have to compile Qt myself and package a new QGIS, but there is a
> >bug in Apple's SDK mechanism that could be the problem.
> I had the same problem trying to compile Qt 4.8 on OS X 10.5.8. QtWebKit does not build (compiler error because of reference to 10.7 function) and QGIS needs Webkit.
> How did you solve the problem? Disable the help menu?
> Regards,
> Marco
> On 25.02.2012 16:24, William Kyngesburye wrote:
>> So I finally packaged QGIS 1.7.4 (I was waiting on a GRASS 6.4.2 problem, but that may take a while).  And...
>> WARNING #1: serious Qt packaging bug
>> Nokia screwed up compiling their "official" binaries.  Everything BUT QtWebKit works on OS X 10.6 (Snow Leopard).  QtWebKit appears to use a OS X 10.7-only system function.  This breaks QGIS help and some plugins on OS X 10.6.
>> It's possible it's not really Nokia's fault.  I'll have to compile Qt myself and package a new QGIS, but there is a bug in Apple's SDK mechanism that could be the problem.
>> WARNING #2: delete existing plugins before running QGIS 1.7.4.  If you can do it before installing QGIS, disable them in the old QGIS, then update and re-enable them one at a time after upgrading QGIS.  If you have already installed 1.7.4, you need to manually delete them from ~/.qgis/python/plugins.
>> I've had a report of plugins directly using a specific GDAL version like 1.8 (I don't know how this is possible), which will crash QGIS 1.7.4 which uses GDAL 1.9.  There also appears to be a problem with PyQwt so the profile plugin will crash QGIS.
>> Sorry for the breakage.  I'll try to fix things as quickly as I can.
>> William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
>> Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
>> First Pogril: I don't know either.  Wretched, isn't it?
>> -HitchHiker's Guide to the Galaxy
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole -  Linux&  Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
