[Qgis-developer] OS X QtWebKit problem fixed, PyQwt still broken
William Kyngesburye
woklist at kyngchaos.com
Mon Feb 27 22:59:52 EST 2012
I configured with:
./configure -sdk /Developer/SDKs/MacOSX10.6.sdk -release -opensource -no-dwarf2 -cocoa -no-qt3support -system-zlib -plugin-sql-sqlite -no-sql-psql -no-sql-mysql -nomake demos -nomake doc -no-prefix-install
Though the no-prefix-install option seems to be a bit off (still compiling to verify). When prefix-install is disabled, Qt installs in OSX paths, like the binary downloads - /Developer and Frameworks. But the framework path appears to be /Libraries/Frameworks, not /Library/Frameworks.
On Feb 27, 2012, at 11:14 AM, Larry Shaffer wrote:
> Hi William,
> On Sun, Feb 26, 2012 at 9:42 PM, William Kyngesburye
> <woklist at kyngchaos.com> wrote:
>> New package online for OS X QGIS 1.7.4. I compiled Qt 4.8 from source and the QtWebKit bug is gone.
> I can confirm QtWebKit is working fine with your 1.7.4-2 build, both
> on 10.7.3 and 10.6.8, on all my Macs, regardless of installed (or no)
> system Qt SDK version. Thank you for getting this to work.
> The problem I had while testing the QtWebKit function of some QGIS
> plugins was how the loading of a local file URL was coded.
> This worked under Qt 4.7.4, but fails with a blank page, due to lack
> of a protocol, on 4.8.0:
> self.helpviewer.setUrl(QUrl(
> os.path.join(plugin_dir, "html", "help.html")))
> It needs to have the file:// protocol expressly added:
> "file://%s"
> % (os.path.join(plugin_dir, "html", "help.html"))))
> This error is present in some currently distributed QGIS plugins. The
> resultant blank web pages made me think your builds weren't working. I
> could find no documentation of this change at Qt's site.
> I'd like to compile nightly builds of QGIS under Snow Leopard, was
> there anything you edited or changed when compiling Qt 4.8.0 to get
> WebKit to work?
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
