[Qgis-developer] Re: [Qgis-user] QGIS 1.7.4
Agustin Lobo alobolistas at gmail.com
Tue Feb 28 07:55:35 EST 2012
Werner,
As far as I can see,
#4567 Fix Union tool to produce correct attribute table
has not been fixed despite the claim in
http://www.qgis.org/en/about-qgis/qgis-releases.html
1. On ubuntu, I get an empty table including the fields of both layers
(i.e, id for one and id_2 for the other)
2. On windows, the table is populated, but the fields are not merged
(i.e, id for one and id_2 for the other),
Should I reopen #4567 ?
Could some body else verify?
This is the kind of error users must be warned about
(btw, "Merge Shapefiles to one" works fine on ubuntu 10.04, but not on windows)
Agus
El día 23 de febrero de 2012 09:52, Werner Macho
<werner.macho at gmail.com> escribió:
> Dear Users and Developers,
> Due to the fact that the qgis-1.7.4.tar.bz2 tarball had some problems which
> leads to being not able to build QGIS on some Systems the problems were
> solved and QGIS now should build on any System.
> As there were only some small changes in the build system, the packages
> which have already been built are not affected.
> To provide a source tarball to all people out there who prefer to build QGIS
> out of the tarball I reuploaded the fixed version of the tarball.
> It is available from the usual download adress
> http://qgis.org/downloads/qgis-1.7.4.tar.bz2
> sorry for the problems that this tarball might have caused to some people
> kind regards
> Werner
> Qgis-user mailing list
