[Qgis-developer] Libeay32 dll version conflict
Jürgen E. Fischer jef at norbit.de
Wed Feb 29 09:28:39 EST 2012
Hi Andreas,
On Wed, 29. Feb 2012 at 14:08:22 +0100, Andreas Neumann wrote:
> Every once in a while I get a dll version conflict when starting QGIS.  Seems
> like Windows has a newer version of libeay32.dll in  \winnt\system32 whereas
> OSGeo4W has a different (older?) version in  C:\Programme\OSGeo4W\bin
The DLL doesn't belong to Windows, but to some other software that also uses
OpenSSL and put the DLL there.
> Anybody knows why there is this version conflict? The system wide
> libeay32.dll - does it have priority over the one in OSGeo4W? Or is  there
> some setting I can use?
Unfortunately the system32 directory has priority and is processed before PATH
is searched (see also [1]).  AFAIK the only way is to (re)move the DLL from
system32 or to put the OSGeo4W version into each osgeo4w directory where
executables that load it are.
Jürgen
[1] http://trac.osgeo.org/osgeo4w/ticket/35
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
