[Qgis-developer] Re: [Quantum-GIS] Heatmap C++ Plugin (#82)
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Jan 9 02:53:35 EST 2012
Hi Jean-Roc
>Marco H. had a patch to set a default file format/compression :
>http://hub.qgis.org/issues/3436
True, it still needs to be applied to master branch (modified to go into
the raster menu instead of the option dialog). There is a larger update
for the raster terrain module anyway, so hopefully it can be done after
that.
Regards,
Marco
On 08.01.2012 18:44, MORREALE Jean Roc wrote:
> Le 08/01/2012 08:25, Paolo Cavallini a écrit :
>> Il 08/01/2012 05:58, Arunmozhi ha scritto:
>>> I have written the Heatmap plugin in C++. The plugin presently takes
>>> in a point layer as input, and the buffer pixel distance and decay
>>> ratio, and produces a heatmap raster in the ASCII grid file format.
>>> I hope this makes a good addition in to QGIS plugins.
>> Thanks a lot Arunmozhi.
>> Can someone review the plugin to see if it is suitable for pulling into
>> master?
>> I think it would make a good addition.
>> Of course it will be preferrable to generalize the output, alowing the
>> user to choose the preferred format. This would be useful also for
>> existing plugins.
>> All the best.
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
