AW: [Qgis-developer] Problem with setting up PyQGIS (QGIS 1.7.3)
Kaps Stefan
stefan.kaps at vorarlberg.at
Thu Jan 12 03:45:38 EST 2012
I am trying inside 2.5 qgis and now it works, but my arcpy scripts (2.6) don't work anymore - and the same vice versa...
I am looking forward for your solution!
Stefan
Von: Robin Cura [mailto:robin.cura at gmail.com]
Gesendet: Donnerstag, 12. Januar 2012 09:37
An: Kaps Stefan
Cc: Jürgen E. Fischer; qgis-developer at lists.osgeo.org
Betreff: Re: [Qgis-developer] Problem with setting up PyQGIS (QGIS 1.7.3)
I haven't experienced for arcpy + pyqgis, but I had the same problem running arcpy + ogr lib.
Whith which python version are you trying this ? Inside the 2.5 qgis python or the 2.6 arcpy python ?
For my part, I had to use a 2.6 python (native, with connections to ogr), and import inside it arcpy, using an external file to "trick" arcpy.
Can't say anymore now as I'm not on this computer, but I'll give you my complete solution later in the day.
Cheers,
Robin
2012/1/12 Kaps Stefan <stefan.kaps at vorarlberg.at<mailto:stefan.kaps at vorarlberg.at>>
Hi Jürgen, Gary, Richard etc.
Thanks for your support! My problem was, that I have allready installed python 2.6 for ArcGIS and this caused my problems when running my python script! I am not able to run arcpy 2.6 and pyqgis 2.5 together - has someone experience with arcpy (python 2.6) and pyqgis running together?
Stefan
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org> [mailto:qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org>] Im Auftrag von Jürgen E. Fischer
Gesendet: Mittwoch, 11. Januar 2012 17:39
An: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Hi Stefan,
On Wed, 11. Jan 2012 at 08:52:27 +0000, Kaps Stefan wrote:
> I'm not able to set up the Python environment for standalone
> applications correctly, allthough there are several documentations on
> the internet -> I am using this one
> [1]http://www.qgis.org/pyqgis-cookbook/intro.html#python-applications,
> but
Create a copy of the qgis.bat file in bin and replace the last line with a call your python(w) script in the copy. That should help.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120112/c8ffecea/attachment-0001.html
