[Qgis-developer] path to the qgs file for qgis-server
Marco Hugentobler marco.hugentobler at sourcepole.ch
Sun Jan 15 15:27:19 EST 2012
Hi Andrea
It is also possible to call QGIS server without map parameter and to
place the .qgs file into the same directory as the qgis_mapserv.fcgi
executable.
In practice, a better solution is to use Apache URL rewriting
(mod_rewrite) to hide the location of the .qgs file from the client.
Like this, you can use nice URLs and if the locations of the .qgs files
change, the server administrator adapts the config accordingly.
Regards,
Marco
On 15.01.2012 21:14, aperi2007 wrote:
> Hi,
> I'm study-ing the qgis-server.
> I notice to call the qgis-server is need to pass also the file-map and
> it eventually path.
> like this:
> http://localhost/cgi/qgis_mapserv.fcgi?MAP=/home/~user/map-files/test.qgs
> this is a bit complicated url.
> Because if I should decide to change the path to the file-map
> this mean the url will change for any user using this qgis-server.
> I like to know if there is some other method to set qgis-server where
> find the file map.
> Thx,
> Andrea.
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
