[Qgis-developer] Expression builder in field calculator
Tim Sutton
lists at linfiniti.com
Mon Jan 16 08:11:43 EST 2012
Hi
On Mon, Jan 16, 2012 at 2:44 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Tim,
> Bugger, I'll check it out.
> What kind of column was it, int, double?
> I had a test with current master and it doesn't seem to have this issue, so
> I'll test my branch a bit more. I didn't change much in that "logic" part
> of the calculator mainly just removing old gui references but I'll check it
> out anyway.
Let me retest this evening and I'll send you a test dataset if I can replicate.
Regards
Tim
> - Nathan
> On Mon, Jan 16, 2012 at 10:09 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Mon, Jan 16, 2012 at 1:01 PM, kimaidou <kimaidou at gmail.com> wrote:
>> > Hi Nathan
>> > Great news !
>> > No objection for me, as it is a great enhancement.
>> > Cheers
>> > Kimaidou
>> > 2012/1/15 Nathan Woodrow <madmanwoo at gmail.com>
>> >> Hi all,
>> >> I spent some time today adding the new expression builder to the field
>> >> calculator.
>> >> The current working version can be found
>> >> at https://github.com/NathanW2/Quantum-GIS/tree/field-calc with a
>> >> picture of
>> >> the current UI attached.
>> >> Could I just get a few people to try it out to test I have everything
>> >> right, and I'm happy to take any feedback people may have.
>> >> If there are no objections I will merge it into master over the next
>> >> few
>> >> days.
>> I did a brief test here - using a simple expression:
>> "depth" / 3
>> applied to the depth field resulted in all nulls. I was expecting it
>> to replace the original value - though I'm not sure if that is an
>> underlying issue or something introduced with your changes.
>> Regards
>> Tim
>> >> - Nathan
>> >> _______________________________________________
>> >> Qgis-developer mailing list
>> >> Qgis-developer at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
