[Qgis-developer] Re: path to the qgs file for qgis-server
aperi2007
aperi2007 at gmail.com
Mon Jan 16 12:29:42 EST 2012
Hi Marco,
>It is also possible to call QGIS server without map parameter and to
>place the .qgs file into the same directory as the qgis_mapserv.fcgi
>executable.
I like to avoid to mix cgi executables from other configuration and
readable files.
>In practice, a better solution is to use Apache URL rewriting
>(mod_rewrite) to hide the location of the .qgs file from the client.
>Like this, you can use nice URLs and if the locations of the .qgs >files
>change, the server administrator adapts the config accordingly.
I don't know the rewrite solution, I don't use apache.
However I guess my web server will have sometime like the apache rewrite.
Thx for hints.
Andrea.
