[Qgis-developer] Plugin repository
Chris Crook ccrook at linz.govt.nz
Mon Jan 16 20:07:34 EST 2012
Hi
I've just updated a python plugin on plugins.qgis.org.  It has come up with some emssages about homepage, tracker and repository field being empty, and a suggestion for creating a project on hub.qgis.org.
All sounds good, so I went to hub.qgis.org, logged in, and created a project.
But I can't see any way to add any content to the project (ie to upload the files).  Is there any documentation anywhere to assist with this?
Thanks
Chris
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank You.
