[Qgis-developer] Problem uploading to contributed plugin repository
Chris Crook ccrook at linz.govt.nz
Mon Jan 16 20:18:26 EST 2012
Hi
I'm trying to upload a modified plugin to the pyqis.org repository.  However when I try to upload the new version I keep getting the error
undefined method `login' for nil:NilClass
RAILS_ROOT: /home/gsherman/development/pyqgis_repository_contributed
Any suggestions on what I can do?
Thanks
Chris
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank You.
