[Qgis-developer] Problem with Postgis 2.0 Views and picking
(info-tool)
Andreas Neumann
a.neumann at carto.net
Tue Jan 17 18:07:46 EST 2012
I recently experimented again with Postgis 2.0 again. I noticed while
loading the Views works fine, that I cannot pick an object with the info
tools.
It works fine with regular tables, but fails for views.
Here is the error message I get in the log:
Fetching from cursor qgisf0 failed
Database error: ERROR: Operation on mixed SRID geometries
Query: CLOSE qgisf0 returned 7 [ERROR: current transaction is aborted,
commands ignored until end of transaction block
1 cursor states lost.
SQL: CLOSE qgisf0
Result: 7 (ERROR: current transaction is aborted, commands ignored
The error message about the mixed geometries is strange, since the view
and the project have the same SRID.
Any idea what could be wrong here? Currently I only have a Postgis 2.0
database available, so I can't test with Postgis 1.5 at the same time.
Maybe with a virtual machine ...
Andreas
