[Qgis-developer] Re: addFeatures without knowing new feature's id, bug?
3nids denis.rouzaud at gmail.com
Wed Jan 18 01:28:21 EST 2012
Hi Giuseppe, Hi Jürgen,
Thanks for the reply, everything is fine! So, thanks for the fix Jürgen!
Btw, is there a way of knowing the ID of a written feature?
As I want to modify it once it is written, I am doing a select to look for
my feature. When using the max+1 solution, it was ok, as I knew the ID. But,
now, I only know its geometry.
Would there be a way of giving back the provider ID to the feature given to
addFeatures?
Or is there any walk around this?
Thanks a lot!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/addFeatures-without-knowing-new-feature-s-id-bug-tp7192256p7199180.html
Sent from the qgis-developer mailing list archive at Nabble.com.
