[Qgis-developer] QGIS on android ALPHA3
Marco Bernasocchi marco at bernawebdesign.ch
Wed Jan 18 09:50:41 EST 2012
*blush*
do I get?
#ifdef android
	include mbernasocchi to about->devs
#endif
On 01/18/2012 02:41 PM, Tim Sutton wrote:
> Hi
> On Wed, Jan 18, 2012 at 11:09 AM, Marco Bernasocchi
> <marco at bernawebdesign.ch>  wrote:
>> Hi all, last night i pushed a new "stablish" version of QGIS for android.
>> I've closed some tickets [0] and thanks to an improvement in master (thx
>> Jef), now the fontsize problem could be fixed as well (I tested it on an
>> asus transformer and it looks great).
>> I fixed some widgets as well which are now not too big anymore and can now
>> be closed. There still are some widgets that are too big (layer properties
>> and raster calculator for example, but we are looking into it.
>> As well I worked a bit on the installation, now there should be no more
>> first run crash. In this version I temporarly disabled the back button which
>> used to crash the app if used. This is not ideal but at least avoids
>> crashing your work when hitting that button. This is a necessitas (Qt on
>> android) known problem and should get fixed in necessitas alpha4 or beta1.
>> As usual you can find all happening around QGIS for android and the
>> installer at [1]
>> I hope in your feed back and remember that any founding you might have/find
>> will help a lot in getting all QGIS on android getting stable faster.
> Well done Marco, keep up the great work!
> Regards
> Tim
>> Ciao Marco
>> [0]http://hub.qgis.org/projects/android-qgis/activity
>> [1]http://android.qgis.org
>> Marco Bernasocchi
>> www.opengis.ch
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Marco Bernasocchi
www.opengis.ch
