[Qgis-developer] Postgis provider, add and modify linestring
Andreas Neumann a.neumann at carto.net
Mon Jan 23 09:28:37 EST 2012
 Hi Denis
 On Mon, 23 Jan 2012 14:47:49 +0100, Denis Rouzaud wrote:
> Hi all,
> I observed a few changes I see as drawbacks.
> 1. When you draw a line, when you right-click to finish the feature,
> the current point is used. I think it is more consistent to place
> points with left-clicks and finish with a right, without adding
> anymore point.
 I think that this behaviour is not new but was always like this. This
 is also a general digitizing issue and has nothing to do with the
 Postgis provider, as far as I know. Personally, I am not sure what is
 easier/best to finish digitizing a line.
 I had a look at other graphic software:
 * Inkscape: finish line with double click or right click, but right
 click does not add a new point. This seems to be in line with what you
 propose above.
 * Autocad: finish a polyline with enter key
 * Openoffice: finish a line with a double click - right-click undoes
 last vertex.
 * Scribus: finish line with right click, but right click does not add a
 new point. In line with Denis' proposal.
 In general I think that QGIS current solution with finishing a line
 with right-click (while adding a new vertex) is not so bad, once you are
 used to it. It means fewer mouse-clicks, which is nice. It might be a
 little unfamiliar for new QGIS users, but I think people can get used to
 it quickly - am I wrong?
 One issue we have with right-click and with double click is that it is
 hard to replicate on a touchpad. Marco Bernasocchi, the current QGIS on
 Android maintainer has to find a workaround because there are no
 right-clicks on a touchpad.
 Any idea about a better way to finish digitizing a line?
> 2. Also, when I finish a feature, I have to commit changes and to
> refresh the canvas before I can see it on the map. If I am right, it
> did not used to be like this.
 That's strange - I cannot observe this behavior. It works fine on my
 machine.
> 3. There is no add/remove node for a linestring. I am going to write
> this as a plugin. I this planned to be done? Did I look too quickly
> and this feature does exist?
 yes - this functionality is missing - and I think it should go into the
 core (not just as a plugin). The functionality to extend a line is a
 core functionality that everyone needs at some point.
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
