[Qgis-developer] Postgis provider, add and modify linestring
Andreas Neumann
a.neumann at carto.net
Mon Jan 23 09:30:56 EST 2012
Denis,
You can remove one or more nodes by selecting them - they become blue -
and then you hit the delete key.
A double click adds a node.
But there is no way to extend and already digitized line beyond the
end. This functionality needs to be added.
Andreas
On Mon, 23 Jan 2012 15:27:12 +0100, Denis Rouzaud wrote:
>> Can't you do that with the node tool?
> Well, as far as I tried, you cannot remove a single node.
> And to add one, double-click seems to add a node (there is a cross
> drawn), but you cannot move it, and it is added in the wrong
> segment.
> Qgis-developer mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
