[Qgis-developer] Postgis-Provider: Sometimes hard to pick primary key dropdown box
Andreas Neumann a.neumann at carto.net
Tue Jan 24 15:47:25 EST 2012
to be more precise: I am on ubuntu 11.04 - KDE.
With my current setup I cannot open the combobox for selecting the the
"Primary Key Column" at all. This means that I cannot open a view where
I have to select the pkey columnn.
I will try going into Gnome to see if it improves.
Andreas
On 01/24/2012 09:05 PM, Andreas Neumann wrote:
> Hi,
> I observed this several times in the past.
> In the tree view of the Postgis-Provider (the tree listing the schemas
> and tables) it is sometimes hard to open the drop-down box with the
> primary key choice.
> It got worse when I increased the font-size in KDE because my screen has
> a rather high-resolution.
> Any other people experiencing problems with picking the pkey column as
> well in this dialogue?
> Andreas
> Qgis-developer mailing list
