[Qgis-developer] Re: [Qgis-user] knock knock - 1.7.4 is outside
Werner Macho
werner.macho at gmail.com
Thu Jan 26 09:37:16 EST 2012
On Thu, 2012-01-26 at 15:26 +0100, Paolo Cavallini wrote:
> Il 26/01/2012 15:22, Sandro Santilli ha scritto:
> > Better a 1.7.4 with a bunch of bugfixes since 1.7.3 than no 1.7.4 at all.
> Sure, but only if there are no bigger bugs, introduced after 1.7.3.
> All the best.
Hi!
Thats what I like to find out with my "Call for testing" ..
I think if the branch gets well tested on different data we'll see if
there are more bugs inside than in 1.7.3 :) .. At least I think 1.7.4
will be better than 1.7.3 allthough it is obvious that not everything
can be fixed ..
I agree with you that all showstoppers should be fixed - but as I can
see some showstoppers are not fixed in master also .. so howto backport
non existing fixes?
Better release it with a "known problems" somewhere in the wiki - as we
already discussed some time ago ..
kind regards
Werner
