[Qgis-developer] CRS and bookmarks #3243
Nathan Woodrow madmanwoo at gmail.com
Sun Jan 29 05:04:53 EST 2012
> - I see that it is possible to edit the bookmark_id and that you can use
> both characters as numbers in it? Choosing an id which already excists just
> silently fails..
> I'm not sure if that 'id' is an internal one, or who is enforcing the
> unicity of the id. But should we not just remove that column? The user
> already has an editable name AND project to make it recongnizable for
> him/her?
+1 from me, it's useless information to the user and only makes it
confusing.
 So I would be in favour of showing the Authority ID instead of the SRID
I thought they were the same thing, if not then what ever has the most
meaning should be shown.
I think it would be better to stop that event, so the user is not changing
> coordinates or names by accident?
+1 The action should be Double click to zoom, F2 to rename.
- Now that is a grid, I think we could maybe put a filter above it (for
> users with long bookmark lists, or to be able to sort on CRS or Projectname?
+1 Should be pretty easy to whack a filter model in there.
- Nathan
On Sun, Jan 29, 2012 at 7:35 PM, Richard Duivenvoorde
<rdmailings at duif.net>wrote:
> Hi Jef et al.,
> thanks for merging/pulling
> https://github.com/qgis/**Quantum-GIS/pull/78<https://github.com/qgis/Quantum-GIS/pull/78>
> and thereby closing
> http://hub.qgis.org/issues/**3243 <http://hub.qgis.org/issues/3243>
> I see that the 'little' bookmark dialog has been removed in favour of the
> bookmark list. Although I did like the little dialog, I think removing
> unnessary gui stuff is good.
> Some remarks:
> silently fails..
> him/her?
> - the last column in th bookmarkslist shows you 'SRID' of the bookmark
> coordinates while for example in the projection selector we show the
> 'Authority ID'.
> Personnaly I feel more comfortable with the Authority ID's, and I think
> the SRID should be a technical/internal ID (but maybe other people feel the
> other way around?).
> - double clicking a row in the list let you zoom to that bookmark
> (preffered, see discussion in http://hub.qgis.org/issues/**3243<http://hub.qgis.org/issues/3243>
> But at this moment it ALSO puts you in edit mode after the zoom..
> What is the opinion of other users/devs?
> If agreed, I can make it a feature request, or even implement this myself
> I think...
> Regards,
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120129/ad69f014/attachment.html
