[Qgis-developer] Re: [Qgis-user] Atlas plugin - create map books
Martin Dobias
wonder.sk at gmail.com
Mon Jan 30 18:39:55 EST 2012
On Thu, Jan 26, 2012 at 5:15 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Martin I have been doing quite a bit of QGIS python programming the
> last few weeks and I must say, it's is a really awesome development
> environment and I could see a lot of merit in replacing what we have
> in app with pure python and then using C++ for core, analysis and gui
> libs. I can see that on new platforms (e.g. android mobile) new
> interfaces are going to be needed and in my opinion it isn't something
> we should discount over the long term. However the massive work
> involved in doing that is probably a show stopper. Just mixing in
> python functionality in the way of gdaltools and ftools seems to me a
> viable way to continue for the medium term. What exactly would you
> vision of a more python centric QGIS amount to?
My vision is roughly the same as you describe: first of all, leave the
libraries (core, gui, analysis) strictly in c++. These are our engines
and they should be robust and fast. However the application code (in
src/app) taking care of GUI usually does not run tasks that need to be
super-fast. This is the area where the possibility to switch from c++
to Python might be useful. The python code could be more compact, not
needing to compile and in case of fatal errors it would just show an
error message instead of crashing whole QGIS.
I certainly do not support rewriting stuff from c++ to python. The
whole point is that by having the possibility to put python code
directly in qgis app we may be more efficient implementing new
features and/or reusing existing code from plugins.
Martin
