[Qgis-developer] plugin dev - save to ogr vector file
rob.j.nickerson at gmail.com rob.j.nickerson at gmail.com
Wed Jul 4 02:54:21 PDT 2012
Correction: Sextante doesn't solve my problem as the fTools algorithms are
still restricted to saving to ESRI shapefiles only (well the centroids
algorithm I tested was).
Rob
On , Rob Nickerson <rob.j.nickerson at gmail.com> wrote:
> On Wednesday, 4 July 2012, Paolo Cavallini cavallini at faunalia.it> wrote:
> > Il 03/07/2012 20:17, Rob Nickerson ha scritto:
> >> I am brand new to QGIS (having got here from my work with
> OpenStreetMap) so apologies
> >> if I am posting this in the wrong place. What I am trying to do is
> adapt the fTools
> >> plugin so that it can save to any ogr verctor file format. The reason
> behind this is
> >> that I found the ESRI shapefile format to be restrictive (eg attribute
> values are
> >> limited to 254 chars - 80 in QGIS??).
> > that would be a very welcome addition, thanks. please note that fTools
> are now
> > incorporated also in Sextante plugin. The plugin also saves by default
> in shp, but
> > users can select other formats as well.
> > could this solve your problem?
> > all the best.
> Sounds like this solves my problem.:-)
> Is it worth spending a few moments to bring qgis online documentation up
> to date? I struggled to find the info I needed :-(
> rob
> > Paolo Cavallini - Faunalia
> > www.faunalia.eu
> > Full contact details at www.faunalia.eu/pc
> > Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120704/e4514c84/attachment.html>
