[Qgis-developer] Compiling QGIS with iODBC driver/library for MacOS X and Linux
William Kyngesburye woklist at kyngchaos.com
Tue Jul 10 06:29:40 PDT 2012
I don't think QGIS has any direct linking with [i]ODBC, but would use the Qt ODBC plugin to connect with an ODBC driver.  Note that I don't include the Qt ODBC plugin in the Mac QGIS, but I could if that is supposed to work.
On Jul 9, 2012, at 10:40 PM, Noli Sicad wrote:
> Hi,
> I think it would be good to compile Compiling QGIS with iODB
> driver/library for Mac OS X and Linux
> QGIS 1.8.0 has support for MSSQL but it would not work in MacOS X and
> Linux with Qt odbc driver (i.e. iodbc) included.
> iODBC is working fine in Mac OS X and Linux.
> Here's the github:
> https://github.com/openlink/iODBC
> http://www.iodbc.org/dataspace/iodbc/wiki/iODBC/
> Here is recent problem using MSSQL with QGIS 1.8.0 in Mac OS X.
> http://osgeo-org.1560.n6.nabble.com/QGIS-MSSQL-2008-Data-import-problem-td4986449.html
> Any instruction how to compile QGIS 1.8.x or master with iODBC?
> Would this work with QGIS source code?
> $ ./configure --prefix=/usr/local --with-iodbc-inidir=/etc
> 	$ make
> 	$ su
> 	# make install
> Thanks.
> Noli
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
