[Qgis-developer] Compiling QGIS with iODBC driver/library for MacOS X and Linux
Nathan Woodrow
madmanwoo at gmail.com
Tue Jul 10 06:35:25 PDT 2012
I run Linux Mint 10 and I can connect to my MS SQL database without
any extra work. Just using the Qt ODBC drivers. You have to use a
ODBC DSN but other then that it works as expected. I might do a blog
post about it if I can get some time.
- Nathan
On Tue, Jul 10, 2012 at 1:40 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi,
> I think it would be good to compile Compiling QGIS with iODB
> driver/library for Mac OS X and Linux
> QGIS 1.8.0 has support for MSSQL but it would not work in MacOS X and
> Linux with Qt odbc driver (i.e. iodbc) included.
> iODBC is working fine in Mac OS X and Linux.
> Here's the github:
> https://github.com/openlink/iODBC
> http://www.iodbc.org/dataspace/iodbc/wiki/iODBC/
> Here is recent problem using MSSQL with QGIS 1.8.0 in Mac OS X.
> http://osgeo-org.1560.n6.nabble.com/QGIS-MSSQL-2008-Data-import-problem-td4986449.html
> Any instruction how to compile QGIS 1.8.x or master with iODBC?
> Would this work with QGIS source code?
> $ ./configure --prefix=/usr/local --with-iodbc-inidir=/etc
> $ make
> $ su
> # make install
> Thanks.
> Noli
> Qgis-developer mailing list
