[Qgis-developer] [Qgis-user] Cast your vote: Default icon theme for QGIS 2.0
Sandro Santilli
strk at keybit.net
Tue Jul 10 13:16:05 PDT 2012
On Tue, Jul 10, 2012 at 10:32:49PM +0300, Micha Silver wrote:
> A question regarding the plans for the QGIS icon theme and the GRASS
> plugin.
> Currently GRASS (standalone) uses Robert's icons, but the QGIS plugin with
> the default theme uses other icons. That already could be a small bit of
> confusion. But when I switch QGIS to the new GIS theme, then some of the
> icons appear duplicated: Add Vector in QGIS and Add GRASS vector use the
> same icon. Another possible source of confusion.
> I'm not sure what I'd suggest to make everything work uniformly. It would
> be ideal if the GRASS application icons were identical to the GRASS plugin
> icons, but *different* from the generic QGIS "Add Vector" and "Add
> raster".
What about "Add vector" is a single icon and which kind of vector is choosen
in a second dialog ? Could be shapefile, postgis, spatialite, grass, ....
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.1
| / 2.1 | http://strk.keybit.net - http://vizzuality.com
`-o------'
