[Qgis-developer] WCS and Raster improvements for QGIS
Andreas Neumann a.neumann at carto.net
Thu Jul 12 05:47:32 PDT 2012
 That sounds fantastic - looking forward to all these improvements!
 The WCS is one more OGC implementation that brings us closer to more
 complete GDI support.
 Personally I am excited about the composer improvements. Together with
 the serial printing initiative from the Atlas plugin we will get a quite
 powerful map and report generation engine.
 I also like the requirement to have tests.
 Once this is all implemented one can see what could be exposed in QGIS
 server and webclient.
 Thanks for the information,
 Andreas
 On Thu, 12 Jul 2012 14:11:11 +0200, Tim Sutton wrote:
> Hi All
> I just wanted to share some development plans we have in order to
> prevent possible duplication of effort. We have been funded by the
> World Bank/GFDRR (Global Fund for Disaster Reduction and Recovery)
> to
> add the following functionalities to QGIS:
> Web Coverage Service Support:
> - Implement test suite for WCS integration
> - Implement support for WCS as a native QGIS raster driver
> - Support addition of WCS layers from python
> - Implement WCS test server and document setup procedure so it can be
> replicated
> - Implement a consistent user interface for adding WCS layers
> Raster Improvements:
> - Resampler branch integration - merge to master and integrate WCS
> branch and ensure that all QGIS tests pass
> - Implement sensible default colour scaling for rasters using 2% and
> 98% cumulative pixel count cut off where no style exists
> - Implement (with c++ and python tests) range based floating point
> raster transparency support in QGIS (singleband rasters only)
> - Implement (with c++ and python tests) save as support for rasters
> in
> QGIS. (Mainly tests required as builds on existing work).
> - Implement support for user manipulation of raster null values in
> QGIS when doing Save as.. (e.g. to specify a new null value).
> - Support specification of region, pixel size and output CRS when
> doing Save as... for rasters
> - Add option (default behaviour) to enable OTF reprojection whenever
> a
> new layer is added that differs in CRS from existing project layers.
> The work will be carried by Radim Blazek under subcontract to
> Linfiniti Consulting CC
> In addition Sourcepole has been contracted by the World Bank/GFDRR to
> add the following improvements to the composer:
> Improvements to QGIS composer:
> - Support graticule labels on specified sides only and ensure
> garticule labels on inside are supported via python API
> - Draw 'zebra style' graticule on borders
> - Support printing degree marker (°) and N/E/S/W in graticule for
> EPGS:4326 maps
> - Support scale bar calculations based on ellipsoid for EPGS:4326
> maps
> - Support placement of html elements on map composer
> - Support overview map bounding box overlay based on extent of
> another map frame
> - Support multipage map compositions with pagination (this will be
> limited to nominating a single table/html frame which can overrun the
> primary frame and then paginate)
> - Ensure composer render to pdf works with python bindings in non-gui
> contexts (raster pdf renderer only)
> - Ensure composer templates can be rendered from python by specifying
> a template file path
> - Allow tokenisation of template elements via python (e.g. by passing
> strings of file paths to replace composer elements in template)
> - Compile a test suite that validates all composer functionality
> works in C++
> works in python
> This work is being carried out in order to support the ongoing work
> we
> are doing with the InaSAFE (Scenario Assessment for Emergencies)
> project that we have been co-developing here at Linfiniti. The
> purpose
> in particular is to support the development of a realtime scenario
> report generator for post earthquake events.
> The InaSAFE project is being developed by BNPB, AusAID and the World
> Bank/GFDRR. You can find more details about the project at
> http://inasafe.org
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release
> Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
